86subaru Posted February 17, 2005 Share Posted February 17, 2005 my 84 brat has a nice weber on it , but boy what pain in the butt to get started , to much gas will flood it ,not enough it will not start , i know webers are nice and gaining extra hp, mpg, but is it worth it ? Link to comment Share on other sites More sharing options...
MorganM Posted February 17, 2005 Share Posted February 17, 2005 You are not alone; several others have decided No, its not worth it. EFI 4 TEH WIN! Link to comment Share on other sites More sharing options...
MilesFox Posted February 17, 2005 Share Posted February 17, 2005 also the bracketry for the choke actuation on jims carb is missing, there are 2 holes on the throttle bracket that looks to take screws for additional linkage does anyone have a picture of the choke mechanismes how it is supposed to be for front mounted, throttle on the passenger side, electric choke pull off looks as if the linkages were removed to clear the distrubutor. any pics would help as i could make something for jim if have an idea of what its supposed to look like Link to comment Share on other sites More sharing options...
thedoctor Posted February 19, 2005 Share Posted February 19, 2005 What's this? This is the first anti-weber talk I've heard. Of course I am totally wet behind the ears. Is there widespread agreement about this? I was advised quite strongly to get rid of my undersized Carter-Weber and get a Weber. My whole reason for beginning this search was a no start condition. The last thing I want is a hard starting carb. Link to comment Share on other sites More sharing options...
the sucker king Posted February 19, 2005 Share Posted February 19, 2005 i've not had any problems with my weber when starting, had it for a year, much better than the hitachi, which had a tempermental choke. the weber runs WAY smoother too. maybe something is wrong here. really my weber fires up every time, no problems. i have heard they are prone to icing though i've never experienced it. worth it? good god yes. Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted February 19, 2005 Share Posted February 19, 2005 Is my weber hard to start in the cold? Yes But... I get way more power, better mileage and a smoother idle. If adjusted properly (and all I did is play with the screws, no new jets yet) they are not too hard to live with. Link to comment Share on other sites More sharing options...
86subaru Posted February 19, 2005 Author Share Posted February 19, 2005 well , while changing the oil pump seals i broke the rear piece that goes onto the pump, so now a new oil pump , so no running brat Link to comment Share on other sites More sharing options...
subestyle18 Posted February 19, 2005 Share Posted February 19, 2005 What is "properly adjusted?" Mine is new from carbs unlimited and still runs funky. Starts every time including after sitting in 10f temps. I seem to try a new adjustments every couple weeks, each seem to have their +'s and -'s. I would seem low on power and so i richened it up a little, more top end but would die when ever i came to a stop after getting off the freeway. Lean it out, i would get less mpg's but wouldnt die. I am just trying to find a happy medium. Also twice when returning from the mountians i have had it all of a sudden loose a lot of power, had to keep it floored to keep moving in 4th gear. It would die when ever i came to a stop and then it would be fine when i restarted. Almost seemed that the first barrel was not open and i had to get into the 2nd to get any power. I am going to find a good carb guy to take a look at it and see what he says. Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted February 19, 2005 Share Posted February 19, 2005 Usually I and another person (helps to have a second ear) adjust the mix screw til it sounds decent. Then adjust the idle til its where I want. Mine is like 800 RPM idle warm, like 600 cold... so sometimes it stalls on a cold morning, but not often. If I push the gas once and ONLY once, it will idle at 1500 cold like it should, but its harder to start that way so I just deal with the 600 or so cold RPM's for the first few blocks. Link to comment Share on other sites More sharing options...
TomRhere Posted February 19, 2005 Share Posted February 19, 2005 Got a couple pics here I can email to you. Not sure if they'll show you what you want to see though. Maybe go with a manual choke set-up on it instead???? Link to comment Share on other sites More sharing options...
dragonwingsubaru Posted February 19, 2005 Share Posted February 19, 2005 manuel chokes suck i wouldnt even bother with it, great for startup but once it is warm its a pita if u get on the gas at all because u gotta keep messing with it all the time i personally would rather run with no choke at all than a manuel choke Link to comment Share on other sites More sharing options...
TomRhere Posted February 20, 2005 Share Posted February 20, 2005 manuel chokes suck i wouldnt even bother with it, great for startup but once it is warm its a pita if u get on the gas at all because u gotta keep messing with it all the time i personally would rather run with no choke at all than a manuel choke I learned to drive with vehicles that were manual choke, as I'm sure there are other members here that did as well. It just takes a little bit of finesse with choke position/engine speed is all. Very doable on a Manual tranny, but it truly sucks on an Auto tranny. I've converted many a car to manual choke vs auto choke, just 'cause choke system was FUBAR. Jim, I will get out to the garage and see if I can tell what/where that loose linkage arm goes to. Will be in the AM though. Send you email on findings. Link to comment Share on other sites More sharing options...
dragonwingsubaru Posted February 20, 2005 Share Posted February 20, 2005 yeah both the manual chokes i had b4 were on autos but i still personally thing they suck, would think even more on a manual tranny since u usually get the rpm's up a bit higher before u shift, or at least i do Link to comment Share on other sites More sharing options...
thedoctor Posted February 20, 2005 Share Posted February 20, 2005 Would anyone out there say Hitachi over Weber? I can live with my Carter-Weber for a while yet. Is the consensus that, as long as I am going to be swapping intake manifolds, it would be better to get a Weber rather than to rebuild the Hitachi? Link to comment Share on other sites More sharing options...
mcbrat Posted February 21, 2005 Share Posted February 21, 2005 something to keep in mind also, is tht they will run crappier with bad mpg if the disty vac advance is bad.... I put the old MityVac on the disty this morning, and no vac at all. wasn't even a slow leak. wouldn't hold anything... luckily I had a new one handy, so I replaced mine this morning and everything is running much smoother... Link to comment Share on other sites More sharing options...
