SilverSubie Posted February 20, 2005 Share Posted February 20, 2005 The cv boots split on the 96 Legacy, and I figure I just might as well replace the entire half shaft (front passenger). Though I was looking through the manual, and I am missing a couple tools. Where would be a good place to either buy or rent the axel remover and ball joint tool? Link to comment Share on other sites More sharing options...
lmdew Posted February 20, 2005 Share Posted February 20, 2005 Nothing needed for the axle. Just pull it out. The inner joint, you need a pin punch to drive out the pin. The balljoint does not need to come out completely. Just pull the bottom strut bolt, drop the torsion bar link and you can pry down the A-arm. That way you do not have to get a new alingnment. Later, Larry Link to comment Share on other sites More sharing options...
lmdew Posted February 20, 2005 Share Posted February 20, 2005 I have used axles, $10 each. Link to comment Share on other sites More sharing options...
subie94 Posted February 20, 2005 Share Posted February 20, 2005 lmdew said: Nothing needed for the axle. Just pull it out. The inner joint, you need a pin punch to drive out the pin. The balljoint does not need to come out completely. Just pull the bottom strut bolt, drop the torsion bar link and you can pry down the A-arm. That way you do not have to get a new alingnment. Later, Larry yup that's how i've done it before Link to comment Share on other sites More sharing options...
Olnick Posted February 20, 2005 Share Posted February 20, 2005 SilverSubie--do a search here on the board. Edrach (the axle guru!) did an excellent writeup of the procedure a while back. Good luck! Link to comment Share on other sites More sharing options...
SilverSubie Posted February 20, 2005 Author Share Posted February 20, 2005 Olnick said: SilverSubie--do a search here on the board. Edrach (the axle guru!) did an excellent writeup of the procedure a while back. Good luck! Thanks! I will search around. Stupid Chiltons. Link to comment Share on other sites More sharing options...
