WJM Posted February 21, 2005 Share Posted February 21, 2005 I need some 5MM or 10MM wheel spacers for the RX. Where can I find a set for under $20 for all 4 corners? Yes yes...I am working on finding some longer wheel botl studs...15MM longer too. Link to comment Share on other sites More sharing options...
Snowman Posted February 21, 2005 Share Posted February 21, 2005 Check NAPA? I saw various spacers up on the wall there. Don't know if they'd have anything that fits a 4X140, but it's worth a shot. Link to comment Share on other sites More sharing options...
boing Posted February 21, 2005 Share Posted February 21, 2005 If nothing else... maybe consider cutting some heavy pipe to the size you need. I've done it before with no problems. PAP or other wrecking yards are a good place to go too. Link to comment Share on other sites More sharing options...
All_talk Posted February 21, 2005 Share Posted February 21, 2005 If you cant find any I might be able make you some, dont know if I can do it for $5 a wheel tho. Gary Link to comment Share on other sites More sharing options...
torxxx Posted February 21, 2005 Share Posted February 21, 2005 get some stainless steel metric washers. I've ran my wagon with ea81 rims with those washers to offset them so the rim didnt rub on the caliper. they work just fine. Link to comment Share on other sites More sharing options...
