Alex C Posted February 21, 2005 Share Posted February 21, 2005 Why? I mean I can see the point, but doesnt that mean all the contaminents stay in your system for that long? Alex Link to comment Share on other sites More sharing options...
85Sub4WD Posted February 21, 2005 Share Posted February 21, 2005 yes no filter can get everything - most of the most harmful contaminates can pass through ALL available filters because they are physically similar to oil, just chemically different - mainly blowby gasses and acids that come from reactions between the oil and blowby gasses I do mine every 3000 myself - it's a subaru, it's easy AND cheap Link to comment Share on other sites More sharing options...
swervey87gl Posted February 21, 2005 Share Posted February 21, 2005 Pretty much all oil that is made is literaly rated for that long. Because of the contaminates the oil needs to be changed. There is no way to predict how oil will last with different so many different filters. All it is is just a sales pitch. Link to comment Share on other sites More sharing options...
maximumBRAT Posted February 21, 2005 Share Posted February 21, 2005 Good question.. Link to comment Share on other sites More sharing options...
hooziewhatsit Posted February 21, 2005 Share Posted February 21, 2005 I just saw the same ad for Mobile oil. The oil probably just has more of the 'stuff' that traps contaminates, so it can theoretically go longer before changes. However, more 'stuff' means less actual oil... Link to comment Share on other sites More sharing options...
85Sub4WD Posted February 21, 2005 Share Posted February 21, 2005 hooziewhatsit said: more 'stuff' means less actual oil... not necessarily as the oil itself is what does the trapping - the "stuff" added is just added to change its viscosity range, hence why I don't like 10w-40 - too much stuff added. Realize that the more "stuff" trapped in the oil means the less protection the oil is really giving your engine as it is carring all of that "stuff" over, through, and around the bearings and everything else it's just bad karma Link to comment Share on other sites More sharing options...
Syrinx Posted February 21, 2005 Share Posted February 21, 2005 cheap oil at regular intervals I believe is always better than fancy oil at long intervals for the reasons stated above. Oil is Oil is Oil. It is all the same carbon based goo dead dinasours gave us, regardless of the label or additives. Link to comment Share on other sites More sharing options...
erik litchy Posted February 21, 2005 Share Posted February 21, 2005 Syrinx said: cheap oil at regular intervals I believe is always better than fancy oil at long intervals for the reasons stated above. Oil is Oil is Oil. It is all the same carbon based goo dead dinasours gave us, regardless of the label or additives. not if its PAO based stock instead of hydrocracked. imo i would change the oil filters at 3k miles and leave the oil alone. Link to comment Share on other sites More sharing options...
85Sub4WD Posted February 21, 2005 Share Posted February 21, 2005 Syrinx said: cheap oil at regular intervals I believe is always better than fancy oil at long intervals for the reasons stated above. Oil is Oil is Oil. It is all the same carbon based goo dead dinasours gave us, regardless of the label or additives. Yes and no, cheap (Quaker State) oil has had a tendency to build up wax in bad places and spin bearings, and also gell in a bad way. This was mainly due to refining issues - I still don't use Quaker State because I have seen it do some VERY weird stuff if it sits too long in the bottle - even sealed and unopened. Moderately priced (Castrol/Mobil - not 1) at regular intervals is best. I generally consier anything over $2.50 a quart to be excessive - I usually run Castrol Synthetic Blend b/c I have found it to work really well, and it is reasonably priced. Regular oil changes are always cheaper than an ocasional engine rebuild. Link to comment Share on other sites More sharing options...
