75skunkaroo Posted February 21, 2005 Share Posted February 21, 2005 ok, to make a long story short, the '75 has had a bad vibration anywhere over 35mph, caused by a bent wheel, or so i thought. wham! dead wrong. the front mount for the rear diff has bad bushings. is there anyway of pounding the old ones out and finding 'new' ones? i'd replace the mount itself, but it's a little tricky to find. looks like the upper control arm for the rear end of a '69 chevelle. thanks all -mike Link to comment Share on other sites More sharing options...
75skunkaroo Posted February 24, 2005 Author Share Posted February 24, 2005 bump i don't think the car likes having to be 2wd to stop the vibrations. would the window weld stuff work good to fix this problem? -mike Link to comment Share on other sites More sharing options...
Ross Posted February 25, 2005 Share Posted February 25, 2005 most bushings can be replaced, contact your dealer and ask if there is a repalcement available. If not, a parts shop could probabyl find one similar if you take the old one out first Link to comment Share on other sites More sharing options...
MorganM Posted February 25, 2005 Share Posted February 25, 2005 Check out the Marketplace forum under the bushing group buy in. The company that makes those bushings might have the one you are looking for. Link to comment Share on other sites More sharing options...
