EJ20x vs EA82
WJM
what about using the EJ20 rod? its got a longer stroke...but....hmmmm?
i think the wrx rod would put the piston through the head, doesnt it already come flush to the deck at tdc? for that, i could see having to get a custom crank shaft made to accomodate the extra length.
You'd prolly redefine the description of "interfearance engine" :grin:
However maybe not? Whats the stroke of the EJ20 vs. stroke of EA82? Now is there room in the cylinder to compensate for the extra stroke? :-\
with my engine, im not going for different compression or cheap parts, i am trying to build an engine that will be bullet proof.i want an ea82t that will withstand high boost and possibly high rpm. this is, of course, a long term project for me, i dont expect to be finished till at least fall if not winter.
The EJ rods are all longer than EA rods are.
Further, the EA pistons have longer skirts typically, and don't tend to have the piston slap issues that EJ series engines are famous for....some being better than others obviously.
The Compression of the pistons in the ea series is pretty diverse already as well so mixing or matching within the ea or ej engines should be sufficient for most builds. Otherwise like Shadow indicated you could get special pistons like any other import engine.
