Fang Posted February 22, 2005 Share Posted February 22, 2005 I am looking for the best/cheapest place to buy an Air Control Valve for my 1988 GL Wagon. Yep, it is 4WD, Manual with OHC and SPFI. I live near Austin, TX Thanks! -fang Link to comment Share on other sites More sharing options...
85Sub4WD Posted February 22, 2005 Share Posted February 22, 2005 your local PAP junkyard I think an item item like that should be about $10 to $20 in good working condition - but I am a fierce negotiator BTW - You realize you can clean them right? Just spray it out with something caustic and check for freedom of movement - work like new afterwards If the solenoid is bad, then you have to replace it. Link to comment Share on other sites More sharing options...
hooziewhatsit Posted February 22, 2005 Share Posted February 22, 2005 I believe I have one lying around I could let go for cheap if you can't clean yours or find one at a junkyard. -Dave Link to comment Share on other sites More sharing options...
Fang Posted February 23, 2005 Author Share Posted February 23, 2005 I'll try to clean it and either come back begging for one or bragging about what a swell job I did.... now where exactly is the Air Control Valve? -fang Link to comment Share on other sites More sharing options...
85Sub4WD Posted February 23, 2005 Share Posted February 23, 2005 It is on the front of your throttle body - there is a tube that comes in from the top, and it is attached with four screws. Link to comment Share on other sites More sharing options...
hooziewhatsit Posted February 23, 2005 Share Posted February 23, 2005 it's dang near impossible to get the screws with a normal screwdriver. I found a set of vice-grips will break them loose, after that they're finger tight (or loose). Link to comment Share on other sites More sharing options...
Fang Posted February 24, 2005 Author Share Posted February 24, 2005 I took a good look at everything today. (Thanks for the warning about the screws -- you're right!) It turns out that the solenoid is history. To add to the fun I spent most of the afternoon/evening driving to junk yards looking for the part. I just moved to Austin, TX, so I don't know the local junk yards yet. You know the drill: I call a junk yard and ask, "hey, do you have one of these cars?" They say, "sure we've got several of them. Come on down!" I hop in the car and excitedly drive 30 or 45 minutes, and when I get there they say, "Subarus are out in the back left corner somewhere..." An hour later (after a thorough and exhausting search) they say, "Oh, I thought we had one..." Then I drive to the next place in the opposite direction to repeat the same drill. Dang! I’m pooped and still need the part. I will be in the greater Dallas area tomorrow... Maybe I’ll find one there. At this point I am interested in buying one from anyone who has a spare. I can PayPal you the funds if you promise to mail it our quickly! -Fang Link to comment Share on other sites More sharing options...
