JeffS Posted February 22, 2005 Share Posted February 22, 2005 I just got a 2000 Legacy 2.5 engine with about 46K miles from a junkyard. They tested the compression and oil pressure (both were fine) and there are no visible leaks any where on the engine. My question is, what should I replace on this engine while it is out? I was going to do the timing belt, cam seals, crank seals, thermostat, oil and air filter. Should I change anything else? Thanks. Link to comment Share on other sites More sharing options...
Subaru X Posted February 23, 2005 Share Posted February 23, 2005 He he he I would do an early change on those spark plugs too Link to comment Share on other sites More sharing options...
sea#3 Posted February 23, 2005 Share Posted February 23, 2005 Check the seperator plate at the back of the block (black plastic ) just under the flywheel .If it is black update it to an aluminium plate SEA#3 Link to comment Share on other sites More sharing options...
GLCraig Posted February 23, 2005 Share Posted February 23, 2005 You should replace the oil pump seals Link to comment Share on other sites More sharing options...
