djcracker Posted February 23, 2005 Share Posted February 23, 2005 Just put new axle in 92 loyale.2wd Connected ball joint went on ok. Started to hook the tie rod back up, as i started to tighten the nut on the stub it got so far down then the whole stub started to spin with the nut. Any body ever had this problem. How do you solve this. Quote Link to comment Share on other sites More sharing options...
Ross Posted February 23, 2005 Share Posted February 23, 2005 I have had this problem before (i am assuming you are talking about where the ball joint is connectd to the steering knuckle?). You need to remove the nut and clean the threads on both the nut and the ball joint. If they are damaged the nut will need to be replaced, and you will need to run a tapping die down the thread on the ball joint. If you can't get the nut off, tap the bottom of the ball joint with a dead blow hammer (or a regular hammer with a block of wood) to engage the taper enough to be able to turn the nut off. Hope this helps, i know how frustrating this can be! Quote Link to comment Share on other sites More sharing options...
Subi81 Posted February 23, 2005 Share Posted February 23, 2005 yea the hammer trick has worked for me in the past. It kinda "sets" the taper together, but both surfaces have to be clean. Quote Link to comment Share on other sites More sharing options...
calebz Posted February 23, 2005 Share Posted February 23, 2005 Easiest way I have found to deal with this problem is to put a jack under the tie rod end and exert a little pressure. that holds it in place so you can tighten it. Works every time. Quote Link to comment Share on other sites More sharing options...
RenaissanceMan Posted February 23, 2005 Share Posted February 23, 2005 Impact gun or butterfly always solved that frustration and was a lot faster. God bless air tools. Quote Link to comment Share on other sites More sharing options...
MilesFox Posted February 23, 2005 Share Posted February 23, 2005 yeah its tapered, it holds still with tourque like caleb said put a jack under the tie rod and let it put some tension to hold the works still, once the nut starts to torque down she will hold on her own. nothing is wrong with it thats just how it fits together Quote Link to comment Share on other sites More sharing options...
