[HTi]Johnson Posted February 23, 2005 Share Posted February 23, 2005 What is it? I mean, what's it do? [HTi]JOhnson P.S. I'm throwing Code 23 (Air Flow Meter)...but the car runs..a little rough, at times... could it be the bad Purge Control? Link to comment Share on other sites More sharing options...
GLCraig Posted February 23, 2005 Share Posted February 23, 2005 The purge control solenoid, opens to allow gas vapor to enter the intake manifold from the charcoal canister. If I remember right it dose this at startup and the ECU closes the solenoid after the engine reaches a certain temperature. If you are getting a code for the air flow meter then there is something not right with the airflow meter or the wiring. Link to comment Share on other sites More sharing options...
The Scooby Posted February 23, 2005 Share Posted February 23, 2005 the purge solnoid can purge it at any time other then idle, it uses your unburnet fuel HC's (hydrocarbons) and puts them back into your intake to be burnt, which bacically increaces your engine efficency/mpg Link to comment Share on other sites More sharing options...
