sssor Posted February 26, 2005 Share Posted February 26, 2005 1600engine dies if gas isn't applied. all vacuum hoses appear tight. pvc valve has vacuum. sparks look good, maybe a little hot. any suggestions appreciated. thanks. Shawn Link to comment Share on other sites More sharing options...
85Sub4WD Posted February 26, 2005 Share Posted February 26, 2005 Probably the carb's idle adjustment is off, you will need to adjust the idle speed and mixture. Another possibility is the choke is stuck open, or that the choke adjustment is WAY off. Link to comment Share on other sites More sharing options...
