incognito Posted February 27, 2005 Share Posted February 27, 2005 Well, i was flippin through my spec book and noticed that the oil pressure in an EA82 is supposed to be 57 psi @ 2500 RPM. Now, I'm runnin about 40-42 psi @ 2500 RPMs, havent changed the oil since i bought this car, but i was wondering, if an oilchange doesnt bring the pressure back up is it new oilpump time? By the way, when i first start the car, the oil pressure reads about 70 psi, then after it warms up it goes down to 40-45 psi... could this be an oilchange issue? I personally have never seen this in an EA82 before regardless of oil condition. Thanks for input, Incognito. P.S. - By the way, someone told me when they switched out their oilpump that they had never felt so much power out of an EA82.. is this jive b.s. or will switchin out an oilpump do that? Thanks again. Link to comment Share on other sites More sharing options...
phishy75 Posted February 28, 2005 Share Posted February 28, 2005 Well, i was flippin through my spec book and noticed that the oil pressure in an EA82 is supposed to be 57 psi @ 2500 RPM. Now, I'm runnin about 40-42 psi @ 2500 RPMs, havent changed the oil since i bought this car, but i was wondering, if an oilchange doesnt bring the pressure back up is it new oilpump time? By the way, when i first start the car, the oil pressure reads about 70 psi, then after it warms up it goes down to 40-45 psi... could this be an oilchange issue? I personally have never seen this in an EA82 before regardless of oil condition. Thanks for input, Incognito. P.S. - By the way, someone told me when they switched out their oilpump that they had never felt so much power out of an EA82.. is this jive b.s. or will switchin out an oilpump do that? Thanks again. Your oil pressure sounds pretty good. I had mine running around 30 psi for a while with no problems, but the the TOD came a knockin. Re-sealing my oil pump (no new parts, just the two orings and the shaft seal) brought the pressure right back up and got rid of the TOD totally. It now runs around 45-50 psi when all heated up (70 psi on starup) and alls well. You really should change your oil in an EA82 every 3-5K miles. It will like you for (and so will your HLA's). As for power difference, I didn't notice much if anything but she sure sounds better:grin: Link to comment Share on other sites More sharing options...
torxxx Posted February 28, 2005 Share Posted February 28, 2005 its a subaru.. as long as the oil pressure gauge needle moves even a 1/4" when its running its fine Link to comment Share on other sites More sharing options...
idosubaru Posted February 28, 2005 Share Posted February 28, 2005 no need to replace your oil pump. and if an oil pump made that much difference in driving there was some other issue, this is not typical. Link to comment Share on other sites More sharing options...
MorganM Posted February 28, 2005 Share Posted February 28, 2005 I'd put on a real oil pressure guage first. See what its really putting out. Some corrosion and extra resistance at the sending unit or in the wire between sending unit and guage could cuase a difference in what your guage reads and what the pump is actually putting out for PSI. After than then you can realyl make some edcuated decisions on what needs to be done; if anything at all. Worst case it sounds like a reseal job. You can buy just the seal kit. Should also be able to get a new impeller shaft. Completely new oil pump assembly is rarely required. Link to comment Share on other sites More sharing options...
MudisFun Posted March 1, 2005 Share Posted March 1, 2005 What are you thinking? Change the oil! I don't cre who you got it from but go down to an auto shop and pick out a flush, one qt. to ever one qt. of oil (I don't care what the bottle says) run for ten+ minutes parked, drain and fill, drive ten miles, drain and fill. I might not up you pressure but it's worth it! Link to comment Share on other sites More sharing options...
incognito Posted March 1, 2005 Author Share Posted March 1, 2005 I know how to change oil, Ive been busy working 15 hour days to even have time to do it. I changed my oil last night, gauge is still showing about the same reading as before. Link to comment Share on other sites More sharing options...
Snowman Posted March 2, 2005 Share Posted March 2, 2005 The stock gauge basically tells you if there is oil pressure or not. It's not an accurate gauge. Subaru motors are notorious for having low oil pressure, but they last forever even then. Your pressure is pretty darn good. Mine runs a little lower than that, and that's with a new pump in a rebuilt 205k engine. My Mobil1 10w30 is a bit thinner than most oils, so that brings the pressure down a little bit. Link to comment Share on other sites More sharing options...
