Petersubaru Posted February 28, 2005 Share Posted February 28, 2005 any ideas as to why my 86 turbo shakes when idleing , but not at all times,.. the car ran well 3 wks ago, during this time it has been sitting without it being started.. Link to comment Share on other sites More sharing options...
elcaminokurt Posted February 28, 2005 Share Posted February 28, 2005 I would have to suggest motor mounts. I know they crack and rot from age. Link to comment Share on other sites More sharing options...
hooziewhatsit Posted February 28, 2005 Share Posted February 28, 2005 Does it run well at higher speeds? I've accidently bumped spark plug wires before, then wondered why it didn't want to start easily, and shook like crazy once it did start. Link to comment Share on other sites More sharing options...
Petersubaru Posted February 28, 2005 Author Share Posted February 28, 2005 it runs great off idle...I will check the plug wires for proper connection Does it run well at higher speeds? I've accidently bumped spark plug wires before, then wondered why it didn't want to start easily, and shook like crazy once it did start. Link to comment Share on other sites More sharing options...
ndu Posted February 28, 2005 Share Posted February 28, 2005 Ya, check the simple things like spark plug wires first....It happened to me before....do not run car with misfire for long, it may damage your catalyst converter.... Link to comment Share on other sites More sharing options...
85Sub4WD Posted March 1, 2005 Share Posted March 1, 2005 I know on N/A motors, a vacuum leak comes to mind - check for anything that could allow unmetered air into the system. Link to comment Share on other sites More sharing options...
incognito Posted March 1, 2005 Share Posted March 1, 2005 Ok, i just got done changing disty cap, rotor, wires, plugs, and did a coil swap to the accel coil... much better.. no more feeling like i have a stroker under the hood. Link to comment Share on other sites More sharing options...
