RainbowRoo Posted March 2, 2005 Share Posted March 2, 2005 I just got a 87 XT GL-10 Turbo, First and formost I need to work on the suspension....it is "Air" The left side has some lift to it and the right front, does too. RR has none, I have gone through the threads and I am going to check this out and try and fix it with some help, from my electrical savy buddy. But, if this does not work, can I use a 88 wagon non adjustable coil overs, on this 87? Front and rear? Any spare parts out there for sale? Any other help or suggestions would be appreciated. Link to comment Share on other sites More sharing options...
Ross Posted March 3, 2005 Share Posted March 3, 2005 The air suspension system is a common prob, i think its usualy the air bags that go. You can swap them for coil overs from another ea82 just fine, its probably not worth trying to fix the air suspension. Link to comment Share on other sites More sharing options...
GLCraig Posted March 3, 2005 Share Posted March 3, 2005 I wouldn't use the struts from a wagon because it will raise your ride height. You should find some from another XT. Link to comment Share on other sites More sharing options...
