Sorry...another carby question
Hitachi carb, when opening the throttle from under the hood, when should the second jet start working ? I rev it up, but only squirting out the main jet. Excuse my lack of knowledge....newbie here :brow:
Only under load - so you the car would have to be moving - vacuum actually opens the second barrel (it increases with load).
my hitachi on my 86 5 speed wagon opens with out load i can stand out side the car and rev it and about a little more then half throttle.
I think they vary with adjustment of the mechanism - there are several different versions of carbs for the EA82 - I think each model year is slightly different and then beyond that there is a difference in 2WD vs. 4WD and auto vs manual tranny plus you are int'l, so it probably has a different carb alltogether- my secondary never opened at idle - if you look at the back of the carb on the side opposite the throttle cable, you can see the vacuum actuator for the secondary throttle
