Strakes Posted March 4, 2005 Share Posted March 4, 2005 Alright...I knocked the PCV tube off (accidentally) when the car was running and it sputtered and almost died. I stuck it back on as quickly as I could, and it ran smooth again. Now I have a CEL light. What should I do to turn it off? Link to comment Share on other sites More sharing options...
Strakes Posted March 5, 2005 Author Share Posted March 5, 2005 Sorry...this is for my 2002 Legacy GT Wagon Link to comment Share on other sites More sharing options...
TheBrian Posted March 5, 2005 Share Posted March 5, 2005 Since it's a 1996 or newer, take it to an Advance or an AutoZone and they can read and clear your Check Engine Light for free. It takes about two minutes. Link to comment Share on other sites More sharing options...
Strakes Posted March 5, 2005 Author Share Posted March 5, 2005 Thanks. I'll go by Advance and see if they can help me. Link to comment Share on other sites More sharing options...
mattocs Posted March 5, 2005 Share Posted March 5, 2005 Unhook the negitive battery cable for like 15 minutes, then let it idle for 5 minutes. This will reset the ECU. If the light comes back on, then take it to auto zone and have them pull the code for you. And...on Subaru Legacys, 1995 and newer, you can use an OBDII reader. I am not sure about other models and it having to be a 96 or newer... Link to comment Share on other sites More sharing options...
Hondasucks Posted March 6, 2005 Share Posted March 6, 2005 Once the Fuel Trim monitor sees the lean condition is gone under the same conditions (engine load + RPM, called a "window") three times in a row, it will shut the CEL off, and the code will be cleared after 40 warm-up cycles (warm up cycle is defined as the coolant temperature rising 40 degrees above startup temperature AND rising to at least 160 degrees) also, unhooking the negative cable MIGHT turn the MIL off but it WILL NOT clear the codes, as they are in Non-Volatile memory. Link to comment Share on other sites More sharing options...
Strakes Posted March 7, 2005 Author Share Posted March 7, 2005 Thanks guys. I wasn't able to find time this weekend to go to advance auto. However, the check engine light went away in (I think) 3 starts over 2 days. So what hondasucks said is correct. Thanks a bunch! Link to comment Share on other sites More sharing options...
Johngenx Posted March 7, 2005 Share Posted March 7, 2005 Unhook the negitive battery cable for like 15 minutes, then let it idle for 5 minutes. This will reset the ECU. This won't work on OBD-II cars. You might be able to put the light out temporarily, but the codes are stored in a flash memory and cannot be erased by taking power away. If the condition persists, the CEL will come back on. If you have removed the condition that is setting off the light, after a number of key cycles and driving, the CEL will go off on it's own. It's quicker to simply clear the CEL with an OBD-II scanner once the offending condition is repaired. Link to comment Share on other sites More sharing options...
