Ea 82 carbed to SPFI
Is there a difference in the actual long block between a carbed 82 and an SPFI or is the difference only in the manifold .I would appreciate any input .
Thank you
Jude
The SPFI long block has higher compression pistons and a different camshafts.
That and there are no ports in the block for the ASV system.
The difference in camshafts is the time of opening and closing - I think the carb's are open longer
But you can indeed swap a carb'd block under an SPFI delivery.Just block the ports.
I've never done the oposite but my guru 30+ year Subaru man says you can,just drill out the port and I believe the threads are there in all SPFI heads.Correct me if I'm wrong on that someone,please.
I think everything is there for the ASV setup. The heads are completely identical aside from that.
As has been said, pistons and cams are different and that's it.
I made beautiful little bolt-on caps for my ASV system - why the heck would you want to carb an SPFI head? - furthermore, why would you bother hooking up the stupid ASV system? - I think it is possible to go the other way, but I would be worried about heat dissappation from the modded head
[Putting a SPFi on a carbed engine is what I was curious about.Sorry about the confusion,and thank you to those who responded.
Jude
Dude,you're 19 and in the Carolinas....up here when you get a little older and money is tighter you might want to do things just to stretch the life of a car a little longer.
I'm not saying that's something I prefer to do,but it can be done.And with about as much effort as making pretty little caps for you portholes.The point is to just lift an intake and stuff a good block underneath.Call it what you want but if it works for a while,why not?We're talking about cars that are disappearing from the roads up here faster than you can say "the sherriff's got the best moonshine around".:)
Some states have serious emissions standards as well.Lack of equipmnet is an automatic failure.Bye bye to a day of effort for lack of a few minutes more of effort.
