For those with welded rear diffs...
tailgatewagon
make shure your spair is the same size as your offroad tires....
i had a flat on the rear today while cruzing up a creek when i got back on pavement my spair was squealing like mad. pulled it off put it up front i handnt thought about it but it was 3in shorter :rolleyes:
anyway just a thought that should be comon sence :o
I'm in with Flow,
A matching spare setup would cost me $130 :eek:
I just figured I'd move the small tire up front or pull an axle.
There is also a remote possiblilty on balancing with 3 wheels?
Glenn,
82 SubaruHummer
01 Forester
When I buy offroad tires for my rigs, I always buy 5, and I buy 6 when I can.
Here's why.
1. Nothing like having a full size spare!
2. If you rotate your spare in from time to time (assuming you only have 1) then you will get 25% more life out of your other tires. . . If you have 2 spares that you rotate in, your tires will last 50% longer.
3. Once you pop a tire, you have to buy that extra one anyways. Then you have a new tire you have to run with worn tires.
i have always gotten 5 tires no matter what rig it was for,but with our 4wd systems it is mandatory that you have 5,at least for a lifted rig.....imo.i have been looking seriously at tires as to purchase in the next couple of weeks and have found alot of reason not to buy 5,but i will .
