Has anyone used a blaster coil & MSD6A?
I searched, and didn't find anything conclusive.
I'm considering putting in a Blaster coil & MSD6A unit. I'm looking mostly for improved fuel economy, but more power wouldn't hurt either. If it turns out it doesn't make much of a difference, I'll just keep the MSD6A around for my RX-7 project car. Am I likely to notice anything from this?
-=Russ=-
when using a blaster 2 what are the plugs gaped at ,.45-.50 ?? like the accell
didnt gap the plugs, just took em outta my other engine cause they were new and bolted em in on the new one. i made sure they werent smashed or broken, i also checked to see if the were uniform, but i didnt have the gap specs or a gapping tool with me when i put em in.
Actually, I might be arranging a dyno day in Des Moines within the next month. If I can get multiple pulls in, I'll get data with the stock ignition system vs the Blaster/MSD6A setup. Assuming I take my Subaru... I might have my project RX-7 running by then.
Also, I'm debating taking some synthetic gearbox/differential lube, and changing it out between pulls - see if there's any noticeable difference in power to the wheels.
-=Russ=-
