March 9, 200521 yr that sounds cool, and it means that when in low (if it is the same as a reg RX box) the gear ratio is like 4.44 I dont think thats right, it should be 4.93:1 in low, or is my math bad? 4.11 x 1.2 = 4.93 With the stock 3.7 and RX 1.2 low you get the 4.44 3.7 x 1.2 = 4.44 BTW, the RX gear ratios work out like a 6 speed (with a really low 1st) if you run it in low and shift to high range after 5th. Gary
March 9, 200521 yr I dont think thats right, it should be 4.93:1 in low, or is my math bad? 4.11 x 1.2 = 4.93 With the stock 3.7 and RX 1.2 low you get the 4.44 3.7 x 1.2 = 4.44 BTW, the RX gear ratios work out like a 6 speed (with a really low 1st) if you run it in low and shift to high range after 5th. Gary I didn't really do any math, I just guessed as I thought when in low it was 4.11s. and yes it is like a 6spd if you drive it like that
