dmeucci Posted March 7, 2005 Share Posted March 7, 2005 Hello All! This is my first post and I wanted to thankyou for helping with the O2 sensor info. Replaced that myself and now have better fuel efficency! Just the other day my ABS light went on and when I turn off the car the ABS motor doesn't stop running. I unpluged the battery for 15mins. and when I reconnected it the motor came on again. So, I disconnected the ABS plug and am stuped on what to do next. The manual says to take it to a tech to get the code on it. Has this happen to anyone else? Ideas? Thanks in advance- David 95 LW Manual with 168k and going strong... Link to comment Share on other sites More sharing options...
lmdew Posted March 8, 2005 Share Posted March 8, 2005 If it turns out you need a new ABS unit, let me know I have the computer and ABS unit from a 96. It should be the same. Lmdew@hotmail.com Link to comment Share on other sites More sharing options...
avk Posted March 9, 2005 Share Posted March 9, 2005 There's a TSB that says this symptom may be caused by a sticking ABS motor relay, and if so the relay should be replaced with an updated part. Link to comment Share on other sites More sharing options...
dmeucci Posted March 9, 2005 Author Share Posted March 9, 2005 avk said: There's a TSB that says this symptom may be caused by a sticking ABS motor relay, and if so the relay should be replaced with an updated part. What does TSB mean? How can I check if that realy does not work? Some one else here offered a '96 ABS unit to sell me. Is the relay seperate from the unit or is it all one piece. Thanks for your help as I am a newbee here- David Link to comment Share on other sites More sharing options...
FlyFlicker Posted March 9, 2005 Share Posted March 9, 2005 This has happened a couple of times on my '92. In the engine compartment you will find a fuse box which contains the relay. Remove the relay for a few minutes and plug it back in. This worked for me. I don't know if the thing gets hot or exactly why it wants to act up and I suppose that one of these days I should pick up a new relay, just haven't done it yet. Link to comment Share on other sites More sharing options...
yarikoptic Posted March 10, 2005 Share Posted March 10, 2005 I've discovered problem with my ABS even though my ABS light wasn't on. I discovered that because I mixed up 6th pin with 5th pin on a diagnostic connector darn... I can't find how to attach files with description of the procedure and codes.... will report later... REVISED: HERE you can grab an ABS.rar file which contains necessary manuals. I'm sorry I don't remember where I got them but I recall that one of the subaru forums has all of them somewhere... mah be even USMB Link to comment Share on other sites More sharing options...
avk Posted March 12, 2005 Share Posted March 12, 2005 "TSB" is a technical service bulletin, those are sent to dealers. To check the relay you can measure the voltage at the coil. If there's no voltage but the pump motor's running, the relay is stuck. The relay is one of the two under the black cover next to the hydro unit. It's probably easier just to buy the "ABS motor relay" and swap it. Chances are, it'll fix the problem. dmeucci said: What does TSB mean? How can I check if that realy does not work? Some one else here offered a '96 ABS unit to sell me. Is the relay seperate from the unit or is it all one piece. Thanks for your help as I am a newbee here- David Link to comment Share on other sites More sharing options...
