Spark gap w/Accel Coil?
I've just stuck with the stock gap on my cars when using the accel coil. You should be able to open it up a little bit more, but originally, I was just trying for a more stable spark under high-boost conditions. On a N/A car, I'd say go ahead and crack it to .050", if you want.
Hi, I have done both. It really doesn't make a lick of difference that I can tell. The Accel makes it start in half a turn instead of a full turn and it does help when cold to open them up a little, but for the most part, you get a good spark either way, just my 2 cents worth, Bradd
