Lesson #1
I have not heard of the optical distys failing all that often..?
I had one fail about a year and a half ago. The car would run for a bit, then miss and stall and not restart for abotu 20 minutes. The ignitor was apparently overheating. 10 minute disty swap and it was all better.
So what happened Will?
Came into a NAPA parking lot...was running perfectly....came back out, woulnt start.
Then...after messing with things...it finally ran just as you described. Luckily I had two spares....but miles away. :banghead:
exactly....i stopped carrying stuff like that after the coolant leak was fixed and the car was getting ~30 MPGs and driving perfectly....I only carried about...1~2 qts of Motul with me and the tool box.
