XT/XT-6 Pulley question?
I too would also like to know as I am swap an XT spider intake on my GL and will be using the water pump timing marks with the standard (unmarked) crank pulley to set the ignition timing. I was thinking that I would mark the pulley at the 0 degree mark on the water pump timing marks when the #1 piston is at TDC. Is that correct?
