torxxx Posted March 9, 2005 Share Posted March 9, 2005 Postin for Subaruthless since I'm already logged in and we use the same computer. It picks up alright under light pressure on the throttle. When you floor it, it doesnt hardly get going at all. noticeable around 3500 rpms. floor it and it doesnt gain speed at all. When we got the Brat it had noticeable blowby in the airbox and filter. we changed the filter. seafoam deep creep'd the carb. I'm thinkin the secondary isnt opening. Or possible the PCV is plugged and its blowing by all the crankcase pressure into the carb causing it to choke itself out. Anyone got any other ideas? Thanks for whoever posts.. Link to comment Share on other sites More sharing options...
Ross Posted March 9, 2005 Share Posted March 9, 2005 Could be caused by a weak spark also. Sounds like what happened when my condenser went bad - it probably got elec ignition though does it? Link to comment Share on other sites More sharing options...
northguy Posted March 9, 2005 Share Posted March 9, 2005 You might also look at the internals of the distributor to see if they move or are stuck. Link to comment Share on other sites More sharing options...
FlyB0y Posted March 11, 2005 Share Posted March 11, 2005 from the sounds of it, could be classic over-rich from a dirty carb, how do the plugs look? I have never used the seafoam, but I think to really know that a carb is clean you need to disassemble it and boil it out with acid, check all the jets/circuits with a torch tip cleaner and compressed air to make sure they are flowing free ... then you KNOW the carb is truly clean :cool: Link to comment Share on other sites More sharing options...
torxxx Posted March 11, 2005 Author Share Posted March 11, 2005 you guys are gonna laugh... I figured it out after he blew a fan belt. It was the belt. One of those V belts with no teeth, it was slipping, and not charging the battery. the coil musta been usin enough power to drain it when he really got on it. New belt from my EA82, thing drives like a champ. Link to comment Share on other sites More sharing options...
FlyB0y Posted March 11, 2005 Share Posted March 11, 2005 Don't feel bad ... I once took my chevy 350 PU to a mechanic to find out why it was loosing power and discovered that the air filter was almost black!! Link to comment Share on other sites More sharing options...
