EA81T to MPFI EA81 :)
TheSubaruJunkie
There is a slight difference in length on Hydro Lifter Pushrods versus Non hydro lifter Rods.....
Also If you have a Hydro block it has Hydro lifters in the bottom at the cam that those pushrods Work with....
If you happen to stick the Loger rods into a Shaved Non hydro Block you could bend Push rods or Valves Possibly....
You can use Non hydro Heads and Pushrods on a Hydro Block, But you need to keep the non- Hydro Components Together....
I had the opposite Problem on my last Built Motor from CCR I sent them a Hydro Block, and Kept all my Pushrods and Rockers here.....I got back a Non hydro Block accidently, with Non hydro Lifters...I put the thing together , and Had ZERO Compression ......???? Due to the fact that the Lifters/pushrods were keeping the valve train open
I had to adjust My Rockers out a Bunch to get it to work.....And change Pushrods out For non hydro Ones......
Hope this Clears it a bit for you......
Later, John
