tizzle Posted March 11, 2005 Share Posted March 11, 2005 As expected, it is the source of my leak. Is there any easy way to fix this. I can't even tell if there is a clamp down there(if there is how would I even deal with it), because I can hardly reach or see under the intake manifold. Do I have to remove the intake manifold, or what? Link to comment Share on other sites More sharing options...
phishy75 Posted March 11, 2005 Share Posted March 11, 2005 I replaced it once on my EA82T without removing the manifold. I got a clamp that could be tightened from the front (not the top) - like a hose clamp, so that it could be clamped down by putting the screwdriver in from the front and torquing it down. Get a long piece of hose so that you have something to push it on with and then trim it to length after you have got it secured under the manifold. It wasn't fun, but it held up for me. I had my manifold off a few weeks ago and was going to redo it, but it was on there fine so I left it. Link to comment Share on other sites More sharing options...
tizzle Posted March 11, 2005 Author Share Posted March 11, 2005 ah, cool! I already bought some hose, and I got a fuel line clamp like your talking about, that might fit. So I'll give that a try. Thanks Link to comment Share on other sites More sharing options...
tizzle Posted March 11, 2005 Author Share Posted March 11, 2005 #@$*!!!! Link to comment Share on other sites More sharing options...
phishy75 Posted March 12, 2005 Share Posted March 12, 2005 #@$*!!!! ??? waddup ??? Link to comment Share on other sites More sharing options...
tizzle Posted March 12, 2005 Author Share Posted March 12, 2005 oh, hose broke, and the last peice wasn't coming off, so I was about ready to just take off the intake manifold, but I removed the fan instead, to get more room to work. So, I'm ok now, got the hose on and putting it back together. Link to comment Share on other sites More sharing options...
X35 Performance Posted March 12, 2005 Share Posted March 12, 2005 I just changed this same @#$@ hose on my EA82T XT, and can offer this easy piece of advise. You need a really long screwdriver, or a 1/4" ratchet with a long extention. Put the hose on, then slide the clamp where it is supposed to go. Then you can stick the long screwdriver in from the pass side through the space in the manifold and tighten it up easy. What works really good is one of those screwdriver shafts that are like a spring so you can tighten it up at an angle. It helps to remove the oil filler tube sometimes too, depending on your type of screwdriver. May not be needed though... It took me a long time and lots of swearing before I figured it out, but now I could change it again in about 5 minutes - pretty easy! Link to comment Share on other sites More sharing options...
