What happened?
I just went through the engine in my 89 GL10 turbo wagon. I replaced both heads with a better set of gen 2's I had. The gen 3's on it were bad! I put new gaskets, oil pump, water pump, seals, etc. I finally get it all back together and fire it up. Now the bad part. When I started it the engine was extremely noisy. Like it had no oil in it. The oil light was on but I figured new oil pump it will take a minute or two and it will quiet down. Nope, that did not happen. The engine let out a death squeal and that was it. I pulled off the oil filter and it was dry. Nothing in the oil pump at all. I have changed a oil pump on my Xt and I had no problems at all. So what could have happened? Except for the oil problem it started up good and wanted to run but, no oil. Just curious. I am done wasting time on this car. I have four other vehicles to worry about. Like spend some time working on my brat. But again, What do you guys think might have happened? Could I have overlooked something when I put the heads on? Would like to see what the board thinks. Thanks.
