Phizinza Posted March 14, 2005 Share Posted March 14, 2005 Ok. EA81 owners, I would like you too tell me when your car really picks up, and what mods (if any) has it got. My EA81 (check sig for whats it got) seems to hit the real power at about 3200RPM. I'm wondering if getting a stock cam, or a low end power one would be worth while. I want lots of power around 1500 to 2500RPM. Thanks! Link to comment Share on other sites More sharing options...
singletrack Posted March 14, 2005 Share Posted March 14, 2005 Phizinza said: I want lots of power around 1500 to 2500RPM. Don't we all! Link to comment Share on other sites More sharing options...
edrach Posted March 14, 2005 Share Posted March 14, 2005 My Brat pulls quite well from 2000 and gets a kick when the secondary opens at 3500. Delta cam and weber. Link to comment Share on other sites More sharing options...
mtnman38 Posted March 14, 2005 Share Posted March 14, 2005 What about getting your disty recurved I know that this will drop that power band. but you lose at the top LT Link to comment Share on other sites More sharing options...
Alex C Posted March 14, 2005 Share Posted March 14, 2005 I have an aftermarket cam, but no clue which one, wish I knew. I also have the stock carb (hitachi) still. Once I get off idle it starts to pull, but not well till about 2500 or so. However, I still have tons of power down low (right off idle) for pushing/pulling etc. It just doesnt accelerate quickly that low. probably cause I have it overloaded and I have 217k original miles on the 3AT. Alex to the person that said cams (plural) was that a mistake or do you have an EA82 to compare with the EA81 question? No offense intended, just curious. Link to comment Share on other sites More sharing options...
archemitis Posted March 14, 2005 Share Posted March 14, 2005 a brat cam is supposed to help with low end torque. i know my brat would beat my ea82, that supposedly had 30 more hp. you need a brat cam, and more compression!. compression is the best low end power gain you can do. other than cubic inches. Link to comment Share on other sites More sharing options...
Phizinza Posted March 15, 2005 Author Share Posted March 15, 2005 is a brat cam some different sort of cam, or does it come in every brat EA81 engine? What about the delta cam ? What do they do to the power and power band? I heard of someone using EA82 rally pistons that were 4mm longer then the normal EA81's. Are these common to find? Or what other way should I go about upping my compression? I'll look into the disty stuff too. My ute spins the front wheels on the road alot, but it just lacks the power to pull over big rocks and up steep and ruff tracks. I'm not to fussed on the power up high. It is a pickup after all!! I would really like to drive a stock brat, but I'd have to pretend I wanted to buy it, not to good at lying... Link to comment Share on other sites More sharing options...
edrach Posted March 15, 2005 Share Posted March 15, 2005 My typo; sorry; it's corrected. Alex C said: to the person that said cams (plural) was that a mistake or do you have an EA82 to compare with the EA81 question? No offense intended, just curious. Link to comment Share on other sites More sharing options...
Alex C Posted March 15, 2005 Share Posted March 15, 2005 No problem, just wanted to be sure. Alex Link to comment Share on other sites More sharing options...
travis Posted March 15, 2005 Share Posted March 15, 2005 I have a 92 Loyalle, so it might not help.......but, my powerbands are on the passenger side right below the resevoir for the blinker fluid. I just upgraded to the bright yellow power bands and seemed to have gained about 10 horses. Keep em tensioned right and they will be no problem for years. Check tension at the same interval you grease the muffler bearings. Link to comment Share on other sites More sharing options...
Phizinza Posted March 17, 2005 Author Share Posted March 17, 2005 lol travis. I'm planing to get a stock cam and some high compression pistons. Can any one help with these parts in Australia? Thanks. Link to comment Share on other sites More sharing options...
Subeast-EA81 Posted March 17, 2005 Share Posted March 17, 2005 Its funny that you use the words "power" and "EA81" on the same paragraph:rolleyes: however my EA81 with full 2 inch stainless exhaust usualy pulls good from 3500 to 4500, never seen 5000 though, so not sure on that avenue. Link to comment Share on other sites More sharing options...
Phizinza Posted March 18, 2005 Author Share Posted March 18, 2005 hmm.. is it really that bad? It's the second most powerful car I've driven. 1st 88 Ford Telstar 2.2 Turbo 2nd 89 Subaru Brumby (with mods) 3rd 90 Nissan Pintara 4th 85 Ford Telstar 2.0 5th ?83? Suzuki 550cc hatch MmmMMMmmm I love the sound of my Brumby the most tho, 2" makes it soo much better. Apart from the half striped exhust head bolts that make me scared to titen the bolts up. Link to comment Share on other sites More sharing options...
