Subaru safety vs Honda, Toyota & Others...
I was just wondering what everyones take was on the saftey of Subaru's vs other popular cars such as Honda's, Toyota's and others?
I'm not thinking about the advantages of AWD, but more along the lines of crashes etc. What are peoples experiences in these areas? I've read many of the crash test results, but I'm curious to know about real world experiences??
Thanks!
Urban Coyote
Thanks!
Urban Coyote
Although your not talking about the AWD advantage..it is possibly one good reason you will not be involved in a crash in the first place.
Just my 2 cents.
At least for 2000 and later models, Subaru models do very well in passive safety tests. The IIHS off-set test is a good indicator of structural strength and passenger cell protection, and Subarus do well.
Also, the Forester is not required to carry the "SUV will roll-over" decal, as it won't roll over like an SUV. My insurance company classifies the Forester as a "stationwagon" and we get an excellent rate with no SUV-surcharge.
As far as active safety goes, Subarus are pretty good. They handle quite well (even the "tall" ones), but I wish they had better brakes. Both our Forester and OBW's brakes are mushy and ineffective compared to the German cars we've owned.
My wifes' uncle and aunt were killed in a head on collision while driving a Subie Legacy. The cabin was pretty much intact, but their bodies still didn't take that rapid deceleration very well. It doesn't matter what you are in at that point.
  • 1 year later...
Thanks!
Urban Coyote
Real World
http://www.ultimatesubaru.org/photos/showgallery.php?cat=932
That was stopped at a red light. Got hit in the rear by a a Dodge Stratus at 55 mph.
I have back prblems (two surgeries maybe a third) but I am here and can walk.
nipper
I clicked on audis of the same year and found numbers to compare.
This breaks it down into stars
http://www.internetautoguide.com/index.html
http://www.safecarguide.com/exp/archive/idx.htm
That decpihpers them better.
Newer then 1998 i think can be found on the NHTSA website
Odd you didnt try the goverment website first, its right there
http://www.nhtsa.dot.gov/ncap/
nipper
I think these cars overall ARE strong, but what can not be predicited is if your body can take such hard force. Like if you were in a car that will NOT crumple NO MATTER what, if you hit a solid cement wall, you can still die, because the vehicle needs to withstand some of that impact!
As the parachutest would say, its not the fall that kills you, its the sudden stop.
There is a point where yes, you wont break any bones, your brain will survive, but the rest of th organs in your body arent as well protected. They can only take so much decelleration so fast.
nipper
my insurance company sent out a comprehensive list of vehicles. it showed the actual injury claims per accident per vehicle...adjusted somehow. unfortunately i don't have it any more. it created a base number of 100 and anything under that reflected a lower number of injury claims for that vehicle relative to others. i'd like actual statistics like that better than stars. maybe i'll call my insurance company.
right on nipper. i've always driven XT6's and have never read or paid any attention to safety, air bags, side impact blah blah blah. wanted to check it out as i get ready to put a legacy on the road too. actually the publication my insurance company sent was an interesting read, that's what got me thinking about it. thanks for the links.
Well I can attest to the strength of a 98 legacy v. a deer at 70mph. I wasn't even sore afterward. Just mad as hell. Replaced hood, fender, headlight, and turn signal. After I paint it in the spring it won't even show.
They are tough. I have put them through trees(4ft springy mesquite trees) and off ~3ft cliffs (98 legacy) with no major damage (cracked a headlight) and no discomfort to the passenger or myself.
A guy made an oncomming left in front of me. He was in a 1991 Mitsubishi Eclipse. I was in a 1982 GL Wagon. I hit him in the passenger door at ~35mph, with enough force that my car bounced and was facing the opposite direction I was travelling. His car was Taco shaped and ~50ft away. The glass in his car shattered so badly there was glass removed from my left ear canal. None of the glass in my Subaru was broken. The seatbelt stretched, allowing my head to hit the dash/steering wheel and cause minor frontal lobe damage. It took me about two weeks to stop stuttering. No memory loss or anything though. I'm not sure what I cut my knee on.. but that's because I took the dash trim out. The spare tires I had in the back crushed the backseat-back flat. That would have caused some serious back problems to any passengers, I luckily had none. I basically walked away from that accident. They did take me to the hospital via ambulance, but I was only there for ~15 minutes. I only did that because I had full coverage with progressive.
All of the Subarus I see wrecked in the junkyards the cabin is always intact.. even the roll-over ones. I have seen 'not good' ones where people went through the windshield, etc. But not wearing your belt is your own fault.
I have seen, in person, much less pleasant things from other types of vehicles. I've rarely ever seen a badly burned Subaru. My favorite thing about the Subaru: In a front end collision the drivetrain is forced UNDER the car instead of INTO the car. Thanks.
-Eli-
Being "tough" is not a good thing. The cabin should be tough, everything else should be fairly soft, so as to decrease acceleration rates body organs have to cope with. I am surprised how little damage nipper's car has in the back for 55mph hit. I'm no specialist in safety design, maybe its the fuel tank in the back, that needs to stay undamaged or smth, but from going to junk yards fairly often I'd expect more damage for that description of accident.
And yeah, adjust your headrests to proper height.
Its even more bizzare, the other driver drove away in his own car. I would bet there was a lot of damage under the front bumper skin, but none that was reported to any insurance company.
You can't see it, but the entire car is twisted. The left rear corner took the brunt of the hit. The passenger copmpartment stayed in tact, amazingly so. The car was driveable for another three weeks, then the AWD started clunking.
The nose was rebuilt in January from being hit while parked. The hood was no longer square, nor were the front fenders.
There is less damage then one would expect because i took my foot off the brake pedal right before impact (i still have nightmares from seeing him coming at me).
nipper
I'm pretty sure it is twisted, with a lot damage, but the fact that it looks ok means that the body acted like a spring, loading first and unloading after, accelerating you, where as it should have adsorbed the impact energy and and used it to deform the body.
  Quote
nipper
I don't think this technique helps you, but it explains why the other guy was able to drive away. When you are on brakes - for a couple of milliseconds friction in your tires holds you in place, with the energy going to deformation of your car, not acceleration.
One of the things everyone SHOULD do when considering any vehicle purchase is pull sample VINs from similar rides you're interested in, then take them to your insurance provider. Suddenly a sweet deal might not be such... Realizing you're going to have to pay those costs year after year. Insurance premiums are a great indicator of real safety as the provider is EXTREMELY biased and bases their rates on the true cost of claims in the past. Their premiums are simply a matter of business.
When I purchased our '05 OBW I used this method and it worked well. When the agent looked up the OBW her reaction was one of disbelief! She wondered outloud how the premium of an auto in the price range of a new OBW could be so low. To me anyway that spoke volumes about safety comparrisons with other manufactures. The insurer base their premiums on ALL factors. In other words not just personal injury but costs of property damage as well as repairs.
Something to think about. She told me that it is surprising how many people don't even consider the cost of insuring a vehicle in their chioce of a new car. Pilgrim 54
  Pilgrim 54 said:
One of the things everyone SHOULD do when considering any vehicle purchase is pull sample VINs from similar rides you're interested in, then take them to your insurance provider. ...
Biggest safety factor is not the car, but the driver. People tend to self select into different cars, and insurance premium you get for particular car does not tell much about the safety equipment of the car itself. Just compare regular Impreza and WRX rates.
