gasket list
It depends. On some or all of the turbos (can't remember which) the water tubes that run to the thermostat, unbolt form the rest of the manifold. If it's leaking where these tubes bolt up then you'll need the gaskets for the tubes and the ones for where the manifold bolts to the head. Also since you're going to be taking off the manifold you might as well replace all of those little water hoses while you're at it.
