ckappler Posted March 16, 2005 Share Posted March 16, 2005 How big is the idler pulley supposed to be? If it is any bigger then the bolt holding it on I guess mine is gone. I was tightening the belt and I could not get it tight enough and then I started to wonder if somehow it had been chaged or something. Any thoughts? Link to comment Share on other sites More sharing options...
MilesFox Posted March 16, 2005 Share Posted March 16, 2005 what motor do you have, turbo, spfi, or carb? there are 3 factory ac setups, is the compressor square or round, and is the alternator inboard or outboard? Link to comment Share on other sites More sharing options...
ckappler Posted March 16, 2005 Author Share Posted March 16, 2005 It is spfi, square compressor and the alt is outboard. (Assuming that means stand alone not built into the engine.) It looks like every other alt i have ever seen if that helps. Link to comment Share on other sites More sharing options...
Erik R Posted March 21, 2005 Share Posted March 21, 2005 If you bought your belt from NAPA or Carquest, they sold you the wrong belt. This has happened to me. The one they give you is too long to tension and the next one smaller is WAY to short. Let me go out to my car and get the # off of my spare...........it's a Gates "Extra Service" belt............no stupid "teeth" on the top or bottom either. OK, it's a #5735.............this is the "back belt", not the one on the alt. Factory installed A/C............... Hope this helps! Link to comment Share on other sites More sharing options...
NorthWet Posted March 21, 2005 Share Posted March 21, 2005 It is spfi, square compressor and the alt is outboard. (Assuming that means stand alone not built into the engine.) It looks like every other alt i have ever seen if that helps. Miles was asking which is further from the engine centerline, the compressor or the alternator. If the alternator is further from the centerline (closer to fender) than the A/C compressor, then the A/C is "factory installed" and uses a certain set of parts. If the A/C compressor is outboard of the alternator then it is "dealer installed" and uses its certain set of parts. (Often (always?) the waterpump is different between dealer and factory A/C.) Link to comment Share on other sites More sharing options...
ckappler Posted March 21, 2005 Author Share Posted March 21, 2005 Thanks guys. Now I get it. AND...good news, kinda, I found my idler pully on my lawn! I guess it separated from the post ot some point. I assume it is shot and will have to try to find another before I need AC! Any thoughts? Link to comment Share on other sites More sharing options...
Erik R Posted March 24, 2005 Share Posted March 24, 2005 If you have the pulley and the attaching bolt (I guess the adjustment nut is gone? Or is the bearing separated?); all you will need is a new bearing. It is a standard industrial bearing..6202 or 6203, I can't remember right now. Less than $10 anyway. Link to comment Share on other sites More sharing options...
ckappler Posted March 24, 2005 Author Share Posted March 24, 2005 Great. Thanks. I will take a look. It looks like the middle is separated from the actual pulley. There is a spring clip (one of them "u" jobbies) inside though!) Link to comment Share on other sites More sharing options...
ckappler Posted March 24, 2005 Author Share Posted March 24, 2005 Also, stupid me, discovered the downside to running w/o the AC belt.... While it does not effect anything, no front defrost. I forgot that that uses the AC! Realized it last night in a blizzard when the CEL came on and the engine was running wierd! Link to comment Share on other sites More sharing options...
ckappler Posted June 10, 2005 Author Share Posted June 10, 2005 Just got around to doing this now that it is hot out! Anyway, I did indeed buy the wrong belt. The AC compres is farthest from center so I assume that is dealer installed. So....what size is the proper ac belt for this. I measured and it looked to be over 44 inches. Please let me know if you know. Thanks. Link to comment Share on other sites More sharing options...
