front strut bar for 82 brat?
  • 2 weeks later...
So I am in the process of building one.
IIFK the purpose of the bar is to put tension on the strut towers and form a solid link between the two strut towers. This would eliminate body flex.
Design calls for two mounting plates on the strut towers.
Then I have a bar in the middle. To create tension I will get a huge screw and that will be mounted to the mounting plate adjustable at the center bar.
So.... does anyone know if it is best to make the strut bar pull the struts in or push them out. The two that I have installed both pushed.
I could make it do both, but that would require a bit more engineering.
BW
you could always get a peice in the center that is threaded on both sides, in opposite directions, that you can turn to either loosen or tighten the brace. think of the supports that are on some old screen doors and gates..
it could work.
Generally, the bar just supports the struts in their original position. With the subie, you could have it pushing the struts apart, as this will reduce the funny camber they have from the factory.
  • 4 months later...
