Engine "flutters" after warm up.
I just finished putting in an '85 XT MPFI Engine into my '88 GL WGN (spfi - engine died). The problem I'm having is with the idle after warm up. When I start the engine cold, it goes to high idle just fine and runs smooth. But when it warms up it will intermittently "flutter" and drops rpm, then tries to recover; and when I try to rev it a little it will "flutter" until the rpm get way up. Do I have a vacuum problem or a sensor issue? :confused:
Help!
