I have a 92 Legacy Sedan FWD Auto and the drivers side has excessive play in the stub shaft. I checked the bearing retainer for the differential housing and it was tight. The play is between the stub shaft an the differential housing.
Anyone have the limits in the clearance between the parts?
Does it require a differential rebuild to fix this?
Thanks Larry
