How much does a 2.2 EJ22 weigh?
I have an entire long block, pulled from a 1990 Legacy complete with intake, alternator, PS pump, AC compressor, engine sensors, wiring, motor mounts etc. Basically everything to just "drop it in the car" but not exhaust or flywheel/flex plate.
Does anyone know the approx weight of this configuration? (for shipping purposes).
There is no way I can hold it while standing on a bathroom scale...
Damn, I didn't realize that I was that strong. I have dead lifted an EJ22 from the engine bay of a car in a wrecking yard into a wheelbarrow I had place beside the car. I doubt that I can lift 300 pounds. I guess I'll stop by Gold's Gym and see if I can.
PS: I did remove the A/C pump, P/S pump, and alternator before lifting it, it still had the flywheel and clutch on it though.
Why can't you just put a small piece of wood on the bathroom scale and tip the engine up on it, keeping it balanced. I can't see it weighing more than 200lbs.
I was hoping someone had already done this...
I've seen that done, and posted to a Subaru forum. Either here or on NASIOC. It weighed in at 250lbs, and that included the a steel plate placed on the scale, and a few links of the chain he was lifting it with.
Gee, I have one of those in my shed, it isn't that much heavier then the N/A EJ22.
Weight of my motor with a bunch of boxes was like 400 lbs. There was around 100 lbs worth of other boxes on the pallet......only saying what I've seen....
