blabla Posted March 20, 2005 Share Posted March 20, 2005 I've got a 97 obw with 148k that throws a cylinder 1 misfire code every couple of weeks or so. Initially I replaced the plugs and wires and put some injector cleaner in the tank and it went away. Two weeks later it comes back and I had autozone delete it. But, it keeps coming back and I just have it deleted again. No rhyme or reason. I don't feel any laspe in performance when I get the light, it seems totally random. Would a bad coil cause a misfire so randomly? Do I have a bad injector? What's the next step? Any ideas are greatly appreciated. Thanks Link to comment Share on other sites More sharing options...
Meeky Moose Posted March 20, 2005 Share Posted March 20, 2005 if the misfire codes jump from one cylinder to another, i would say you got a coil pack going out.. Link to comment Share on other sites More sharing options...
lmdew Posted March 20, 2005 Share Posted March 20, 2005 I have a good coil pack if you want to try it $35 shipped. Lmdew@hotmail.com Link to comment Share on other sites More sharing options...
Fletch5958 Posted March 20, 2005 Share Posted March 20, 2005 I am having the same problem, only mine is showing misfire on cylinders 1 and 3. Engine runs great. Getting about 21.5 MPG and I have already replaced the coil pack, wires and plugs. But it still keeps coming back. I have cleared it about 10 times in the last 3 months. Link to comment Share on other sites More sharing options...
blabla Posted March 20, 2005 Author Share Posted March 20, 2005 I am having the same problem, only mine is showing misfire on cylinders 1 and 3. Engine runs great. Getting about 21.5 MPG and I have already replaced the coil pack, wires and plugs. But it still keeps coming back. I have cleared it about 10 times in the last 3 months. If you replaced your coil pack as well, what does that leave? Injectors? How does the ecm detect the misfire? Maybe we have a problem there. I really don't know what to do next. I guess the good news is the engine runs well and it's more annoying than anything. Let me know if you figure it out. thanks Link to comment Share on other sites More sharing options...
frag Posted March 20, 2005 Share Posted March 20, 2005 If you replaced your coil pack as well, what does that leave? Injectors? How does the ecm detect the misfire? Maybe we have a problem there. I really don't know what to do next. I guess the good news is the engine runs well and it's more annoying than anything. Let me know if you figure it out. thanks If electrical,that leaves the ignitor If fuel related, that leaves the injector If mechanical, that leaves a valve problem Link to comment Share on other sites More sharing options...
garthpro Posted January 11, 2008 Share Posted January 11, 2008 I've got a 97 obw with 148k that throws a cylinder 1 misfire code every couple of weeks or so. Initially I replaced the plugs and wires and put some injector cleaner in the tank and it went away. Two weeks later it comes back and I had autozone delete it. But, it keeps coming back and I just have it deleted again. No rhyme or reason. I don't feel any laspe in performance when I get the light, it seems totally random. Would a bad coil cause a misfire so randomly? Do I have a bad injector? What's the next step? Any ideas are greatly appreciated. Thanks WHat was your final solution to this problem? I am having a similar one. Link to comment Share on other sites More sharing options...
