lostinthebush Posted March 21, 2005 Share Posted March 21, 2005 ouch car overheating like mad and did everything under the sun but fix the head gaskets, subaru took one look and determined that it was the head gaskets and now its gonna cost 2400$ to get it fixed. i was going to ask in regards to loosing heat from the heater is this a direct result of blown head gaskets? also does subaru warentee their work thanks Link to comment Share on other sites More sharing options...
later, Peter Posted March 22, 2005 Share Posted March 22, 2005 ouch car overheating like mad and did everything under the sun but fix the head gaskets, subaru took one look and determined that it was the head gaskets and now its gonna cost 2400$ to get it fixed. i was going to ask in regards to loosing heat from the heater is this a direct result of blown head gaskets? also does subaru warentee their work thanks I think I would be checking with other non-dealer Subaru mechanics... the quote for my 2.5 99 obw was $900, but I never had the job done. Although, still a wad o' dough, it's quite a bit better than $2400... This was by folks that ONLY work on Subarus Later, Peter Link to comment Share on other sites More sharing options...
idosubaru Posted March 22, 2005 Share Posted March 22, 2005 bad headgaskets will loose coolant. once the coolant loss is enough to prevent sufficient flow to your heater core you will indeed loose any heat eventhough the engine temps keep climbing. this is typical of head gasket failure. other things can cause lack of heat from the heater as well, but i think you know that. 2,400 sounds high. you can find another 2.2 liter impreza outback motor for less than a thousand. if you drove the car for any length of time with bad headgaskets that's not good for the rod bearings and other internals. water mixes with oil and continuous driving like that is not good for motor. Link to comment Share on other sites More sharing options...
brus brother Posted March 22, 2005 Share Posted March 22, 2005 http://www.ultimatesubaru.org/forum/showthread.php?t=1138&highlight=Ccr+engine CCR Engines Inc. has a good rep on this site for the dollar range you mentioned and you get a totally rebuilt engine for probably less than what you were quoted. You get a 36K/3 year warranty on the engine top to bottom. The above link has opinions on merit of rebuild or HG alone. Link to comment Share on other sites More sharing options...
