Spring in bearing
Hi, Just doing a front axle replacment on MY83Wagon. When I removed the CastleNut/Washer/ behind the Cone Washer I fine this tangled mess that looks like a 1mm spring, about 4in long and was probably round but now a mess.
What is it ? I have never seen one before.
Thanx
it fell out of the outer bearing seal. i assume you found this after rmoving the rotor? anyway its what holds the seal tight against its sealing surface
you should replace that seal and inspect the bearings
Hi, Just doing an front axle replacment on MY83Wagon. When I removed the CastleNut/Washer/ behind the Cone Washer I fine this tangled mess that looks like a 1mm spring, about 4in long and was probably round but now a mess.
Thanx
you will have to pry out the old seal to replace it. it wont hurt anything but it could allow contaminates to get into the wheel bearings
the bearings will last as long as the seals do, so if you got a bad seal replace it before it ruins the bearings
but you may as well do the bearings if its gonna be apart, for peace of mind
