Are all 1983 GL's D/R ??
That '83 GL is almost certain to have a Dual Range 4speed. If its 4WD and its a Manual, its a dual range.
They will take almost anything. Just look around at some of our Subaru's and what we put them through. I have a '84 GL which is the same body style, has the same engine but I lifted it 3" and use it as my primary off-road rig. Some of us here have done even more to them.
-Brian
Stock rim size is 13" rim, stock tires are around 175/70R13.
The bolt pattern our cars have do not match any other bolt pattern for any other 14" or 15" rim other than Peugeot. You will hear alot about them on this board.
Without a lift, you can run 14" peugeot rims and up to 26" tires, and thats after alittle sledge work and alittle fender triming.
-Brian
