Squeaky Wheel !!
When I'm going about 25-35 I hear a squeak coming from my front wheel on the passenger side. It gets alot louder if I let off on the gas. Braking doesn't change the sound. If I throw it in neutral it goes away. Outer CV? I've heard a click a couple of times when it's cranked, but very faint. Boots are fine.
could be a loose axle nut, and the rotor is huttin g the outerh caliper frame, the caliper frame will keep the rotor in place.
does the car jerk the wheel or does the tires chirp when downshifting?
if so, that is what an axle will sound like before breaking in the middle of wisconsin
check the front diff oil. use 90 wt gear oill
