archemitis Posted September 1, 2003 Share Posted September 1, 2003 do turbo ea82s have the same injector, turbo or na? if they are different, what are the flow rates? Link to comment Share on other sites More sharing options...
MilesFox Posted September 1, 2003 Share Posted September 1, 2003 do you mean will they work the same, or one over the other as an upgrade? i have been told that they are bosch n-type. some nissan used a bigger fersion of the ones on subarus. its kind of like your subaru version of the brown fuel injector found in ford svt as un upgrade for ford turbos i would think that the mpfi and turbo would have the same injector, and the computer will determine the flow rate , and that would depend on the differences between mpfi's and turbos programming Link to comment Share on other sites More sharing options...
archemitis Posted September 1, 2003 Author Share Posted September 1, 2003 thats what i was wondering, if the mpfi and turbo mpfi were the same injector. then is the fuel pump different on turbo models? Link to comment Share on other sites More sharing options...
MilesFox Posted September 1, 2003 Share Posted September 1, 2003 from what i know they work the same. i will swap one from an spfi into the gl-10 i just got. something like its even the same(design) as the pump in WRX Link to comment Share on other sites More sharing options...
archemitis Posted September 1, 2003 Author Share Posted September 1, 2003 its like they just forgot to put turbos on some of the mpfis:banana: Link to comment Share on other sites More sharing options...
MilesFox Posted September 1, 2003 Share Posted September 1, 2003 true dat! Link to comment Share on other sites More sharing options...
