[HTi]Johnson Posted March 24, 2005 Share Posted March 24, 2005 Hello. #1 I got my WRX intercooler in today:headbang:. I was wondering on where do i get the vacuum line for the blow off valve, I know it needs vacuum to open.(the diaphram does). #2 All my idiot lights are on even if the ignition is on. Any suggestions on why? #3 My lights pulsate the faster I go, I'm assuming it's the alternator not being to make up for all the spark. #4 When I turn on my heater controls any of them, my temp guage shoots UP to max, then when I turn it off in 30 seconds it goes down back to normal. Link to comment Share on other sites More sharing options...
calebz Posted March 24, 2005 Share Posted March 24, 2005 1- Vacuum lines - about $.50/ft at an auto parts store 2- Idiot lights - Alternator 3- Pulsating lights - Alternator 4- temp gauge - you have an 87+ didgidash? I had the same trouble.. its a ground problem.. I ran some extra grounds under the hood and it went away. I still don't trust it, so I installed an aftermarket gauge in my pillar pod. Link to comment Share on other sites More sharing options...
[HTi]Johnson Posted March 24, 2005 Author Share Posted March 24, 2005 I know where to get vacuum lines...I meant where do they run from...from where to the to the blow off. Sorry for the unclearness. But thanks for all the info. I do have a 1987 Digi dash. What usually goes bad with an alternator? [HTi]Johnson Link to comment Share on other sites More sharing options...
Marck Posted March 24, 2005 Share Posted March 24, 2005 I know where to get vacuum lines...I meant where do they run from...from where to the to the blow off. Sorry for the unclearness.But thanks for all the info. I do have a 1987 Digi dash. What usually goes bad with an alternator? [HTi]Johnson Get the vacuum from tha intake manifold. Look for an intake nipple or T it in with a hose that connects to the intake manifold. Link to comment Share on other sites More sharing options...
