dneufeld Posted March 24, 2005 Share Posted March 24, 2005 hey guys i was just wondering if anyone could tell me what each of these wires is for coming off the dizzy of an 87 ea82t motor. (its the crank position sensor wiring) ive got 4 wires a black one a red one a green one and a white one! thanks Ty Link to comment Share on other sites More sharing options...
archemitis Posted March 24, 2005 Share Posted March 24, 2005 green and white are for the knock sensor. the red one goes to the plus side of the coil, and the black goes to the negative side of the coil. Link to comment Share on other sites More sharing options...
dneufeld Posted March 24, 2005 Author Share Posted March 24, 2005 hmmm i was under the impression that this was the hook up for the crank position sensor which wires into the ecu with one wire being power one ground one reference signal and one position sensor? Link to comment Share on other sites More sharing options...
Cougar Posted March 24, 2005 Share Posted March 24, 2005 I have a manual for the '88 model that shows both the SPFI and MPFI wiring. The colors of the wires match the colors you mention except the green one, mine is black/red, which ties to shield. All wires go to the ECU though the shield also ties to other areas. The drawing does not get detailed enough to show the inside of the disty. You may be able to figure the wiring out using a meter and looking at the voltages. Link to comment Share on other sites More sharing options...
archemitis Posted March 24, 2005 Share Posted March 24, 2005 optical disty or standard. flapper or hotwire? Link to comment Share on other sites More sharing options...
dneufeld Posted March 24, 2005 Author Share Posted March 24, 2005 optical with hot wire maf Link to comment Share on other sites More sharing options...
dneufeld Posted March 24, 2005 Author Share Posted March 24, 2005 now im not sure if its optical or regular, how can i tell? Link to comment Share on other sites More sharing options...
archemitis Posted March 25, 2005 Share Posted March 25, 2005 if your disty has a vac. line going to it, then my info is not correct. if its optical. it just plugs into that one plug, that goes back to the computer, and the coil. Link to comment Share on other sites More sharing options...
dneufeld Posted March 25, 2005 Author Share Posted March 25, 2005 ok well it doesnt have a vaccuum plug so it must be optical, but i dont have any plugs since this is a transplant project. ive just got the four mystery wires. so if your info is correct then which wires end up going to the ecu? Link to comment Share on other sites More sharing options...
Cougar Posted March 25, 2005 Share Posted March 25, 2005 What I stated in my post should be correct for your disty also. All the wires go to the ECU. Link to comment Share on other sites More sharing options...
dneufeld Posted March 25, 2005 Author Share Posted March 25, 2005 ok so they all go to the ecu, my ecu pinout shows crank angle sensor (power)(Red) crank angle sensor (reference)(white) crank angle sensor (position)(green) so if that is correct then is the last dizzy wire (the black one) a ground or does it go to the coil? Link to comment Share on other sites More sharing options...
naru Posted March 25, 2005 Share Posted March 25, 2005 ok so they all go to the ecu, my ecu pinout shows crank angle sensor (power)(Red) crank angle sensor (reference)(white) crank angle sensor (position)(green) so if that is correct then is the last dizzy wire (the black one) a ground or does it go to the coil? Black goes to ECU pin 8. Link to comment Share on other sites More sharing options...
dneufeld Posted March 25, 2005 Author Share Posted March 25, 2005 that would make the black wire the crank angle sensor referance then? Link to comment Share on other sites More sharing options...
naru Posted March 25, 2005 Share Posted March 25, 2005 that would make the black wire the crank angle sensor referance then? Don`t really know,but,I expect it is an ECU sensor ground. My diagram shows White to pin 17. Link to comment Share on other sites More sharing options...
dneufeld Posted March 25, 2005 Author Share Posted March 25, 2005 allrighty so we have got black = reference wire white = position wire now just green and red to go! Link to comment Share on other sites More sharing options...
naru Posted March 25, 2005 Share Posted March 25, 2005 allrighty so we have got black = reference wire white = position wire now just green and red to go! Red to pin 7. No green on my diagram,but,it almost certainly coresponds to Black/Red which goes to pin 10(a shared sensor ground). Link to comment Share on other sites More sharing options...
dneufeld Posted March 25, 2005 Author Share Posted March 25, 2005 allright so green is ground and red is power! sounds good to me i'll have to give it a try! so where does the coil get its signal from? is it pin 37 to the ingition amplifier thingy then the coil? Link to comment Share on other sites More sharing options...
naru Posted March 25, 2005 Share Posted March 25, 2005 allright so green is ground and red is power! sounds good to me i'll have to give it a try! so where does the coil get its signal from? is it pin 37 to the ingition amplifier thingy then the coil? My diagram doesn`t show the ignition amp.Coil signal comes from pin 37 and it is only reasonable that it would go to the amp first. Coil+ to pin 19. Link to comment Share on other sites More sharing options...
dneufeld Posted March 25, 2005 Author Share Posted March 25, 2005 so essentially the coil (-) gets hooked up with pin 37 then (theres the amp inbetween though)? also naru could you send me your diagram if possibe? and thanks for all the help! Link to comment Share on other sites More sharing options...
naru Posted March 25, 2005 Share Posted March 25, 2005 so essentially the coil (-) gets hooked up with pin 37 then (theres the amp inbetween though)? also naru could you send me your diagram if possibe? and thanks for all the help! Scanner is down at the moment,but,there is an 89 FSM here:http://www.finleyweb.net/default.asp?id=142 Link to comment Share on other sites More sharing options...
MilesFox Posted March 25, 2005 Share Posted March 25, 2005 the crank angle sensor(disty) tells the ecu what the rotation of the engine is, the ecu sends the signal as a pulse for the spark to the ign amplifier on the coil bracket(transistor thingy) and the amplifier is what breaks the magnetic fielsd in the coil inducing the spark Link to comment Share on other sites More sharing options...
