JonOfScio Posted September 1, 2003 Share Posted September 1, 2003 I've heard 8 to 10 is good, but if I'm really wanting the performance out of my 92 octane gas, then 12 would be good right? how far should it advanced? thanks. Link to comment Share on other sites More sharing options...
thealleyboy Posted September 1, 2003 Share Posted September 1, 2003 If maximun power is what you are after, you can advance the timing up to the point that you start to get pinging on hard acceleration. If you are running 93, you'll be able to speed things up considerably. I would keep the disty adjustable, and bump it up a bit gradually (every time you fill up), paying attention to drivability and performance. Back off as soon as you start getting adverse symptoms. Eventually, you'll find a "sweet spot" where the car is running at maximun potential. That's when you lock it down, and record the timing. Don't screw around with other brands of gas, or additives when you get it running just right. High performance ignition upgrades aren't a bad idea either if you want to go the timing advance route. The downside is that fuel economy will drop noticebly. Don't be surprised if it drops to 20 or less. good luck, John Link to comment Share on other sites More sharing options...
Hondasucks Posted September 2, 2003 Share Posted September 2, 2003 [Jon] Well, my average before timing was 35mpg. So I think a change of that much is waay too dramatic. But it is advanced to 12 now, and I'm getting some clutch slipping when I try to spin my tires (hehe) So to really take effect, I think i need to do some work past the engine aspect of my car. So far now: coil, plugs, wires, rotor, cap, 2" ID Turbo Muffler, 9" chrome air filter assembly, Valve cover breather mods, PCV valve change, O2 Sensor change, timing at ~12. I now need to get a new clutch (but not as bad as Andrew's sold XT!) and find out if my passenger side exhaust flange is warped or not. So that's the plans for the future (beyond new axles, and buying Caboobaroo's calmaster wheels of course) Link to comment Share on other sites More sharing options...
Hondasucks Posted September 2, 2003 Share Posted September 2, 2003 Dagnabbit Jon, like, hit Logout before ya post when yer at my house :-P:moon: :moon: Link to comment Share on other sites More sharing options...
