WJM Posted March 26, 2005 Share Posted March 26, 2005 Ok....so eventually I will go to an Air/Water IC setup....right now Im going to cahnge my Pit stratagy for the autox to keep the IC cool, the STi TMIC that I have.....so I'll stick with it longer as I cant find the right parts at the right price and some of them are not even avalible. So....the heat exchanger core.... Ive got a Leone AC condensor core, you know, the rad looking thing that goes infront of the rad onthe car...and one from an 02 WRX. I was thinking of using that as the heat exchanger core. However...the only two problems i see with it is...SPACE...and the flow thru it. Im wondering if it will flow enough to be efficient. Hmmmm.... Link to comment Share on other sites More sharing options...
LPGsuperchargedBrumby Posted March 26, 2005 Share Posted March 26, 2005 when i was toying with the idea of an air to water IC setup i thought that a 1000cc superbike radiator would be the way to go as they have the highest thermal exchange value of any exchanger i could get easily secondhand that was small enough to fit in front of engine radiator. and most of them have an electric fan on them as well Link to comment Share on other sites More sharing options...
Do It Sidewayz Posted March 28, 2005 Share Posted March 28, 2005 i don't think an a/c condensor had "ports" in it that are large enought to flow the type of volume you need. I think something along the lines of an oil cooler (bar and plate type) would work much better. Around here we have a place called Princess Auto...kind of like your harbour freight tools...but they have alot more surplus stuff...Often times they have truck oil coolers, or heat exchangers around. I also think for it to be effective you need a large reservior....i think you'll need to hold atleast 4 liters in the reservior..... Link to comment Share on other sites More sharing options...
WJM Posted March 28, 2005 Author Share Posted March 28, 2005 yeah, tahts what I was thinking. hmmmmmm.......hon-duh radiator? Link to comment Share on other sites More sharing options...
