towing with a sube
I have a little 16' sailboat. It doesnt weigh much more than 600 lbs or so. I hardly notice it's there when i tow it with my 4.0 grand cherokee. I am wondering what it would be like towing it behind a brat or other subaru. I have no doubt that it will get down the road alright, but i am wondering about times when the boat has a lot of water in it and it has to come up a steep ramp. How does this work out with the unibody etc..
Also, I thought I had heard somewhere that some subaru trailer hitches basicaly bolt into sheet metal rather than into a frame. This may have just been on my 86 wagon.
Let me know.
-Jack:cornfuzz:
BRAT hitches bolt to the unibody. You could always custom fab a bumper to allow for a larger hitch and a stronger bumper. I don't think you would have a problem with a small boat even full of water. The BRATs have great low end torque. If you did have a problem, throw that bad boy in 4 low and be done with it. I don't see any problem with that. This subject came up about two or three years ago. Same scenario. Boz
I tow a 12 ft john boat and a utility trailer with my 88 hatchback regularly. I pulled the hitch off of another hatchback at a junkyard. It actually bolts to the floor of the cargo area in the rear of the hatchback with 6 bolts. The bolt holes are spaced far apart, so the force from the hitch is spread over most of the back of the car. When I pull the boat/trailer up the ramp, I put it in 4 Low and have never had a problem.
scott
I beach lanch my Hobie all the time with my Hatch. Never been a problem. Just like everyone else, I use low range too.
My hitch bolted to the cargo area too and I reinforced my bumper just for peace of mind.
You shouldn't have any problems towing a small boat.
For what it's worth,
Glenn
82 Hatch, transforming....:temper:
01 Forester, Jealous...:boohoo:
i t0wed a 2 axle trailer with a dead soob and no brakes! tow dolly with a soob. both with ea81 power 2wd 5spd, used 4th gear a lot.
i tore a hitch off a wagon, bolts to the floor and the bumper. towing a small boat should be no problem.
actually, its the # of axles you are towing is what will drag you down.
tow another soob with a rope with no problems too
