Kraven Posted March 28, 2005 Share Posted March 28, 2005 Hi One of the huts on my passenger side rear wheel has damaged the bolt when i was having some new tires put on. The other three are fine. Question is how big (and expensive) a job is it to get that bolt fixed? thanks guys Link to comment Share on other sites More sharing options...
GLCraig Posted March 28, 2005 Share Posted March 28, 2005 It's a pretty easy to replace a wheel stud, if you have the tools needed to take the brake drumb off. After that it's a matter of driving out the bad stud and pressing in a replacement. Link to comment Share on other sites More sharing options...
MilesFox Posted March 28, 2005 Share Posted March 28, 2005 if you get the drum off, tou can use a hammer to knock the stud thru from the front, so it falls out the back. if you get a new stud put it thru the drum, bolt the wheel to the drum, and as you tighten the lug nut it will pop the stud in place Link to comment Share on other sites More sharing options...
