XSNRG Posted March 28, 2005 Share Posted March 28, 2005 What is the difference: Turbo Legacy AWD 5mt N/A Legacy AWD 5mt Also will EJ22 N/A timing covers fit the Turbo 2.2? Thanks! Link to comment Share on other sites More sharing options...
Chef Posted March 28, 2005 Share Posted March 28, 2005 Ahh... one's turbocharged, the other isn't...? You'll need to be a bit more specific as to what you'd like to know. XSNRG said: What is the difference:Turbo Legacy AWD 5mt N/A Legacy AWD 5mt Link to comment Share on other sites More sharing options...
beezer Posted March 28, 2005 Share Posted March 28, 2005 Chef, I think he wants to know the difference in the trans. between the 2. As far as I can see from the owners manual, the differnce is the turbo has a hydraulic clutch where the NA has a cable and the final gear ratios are different. Otherwise I think they are the same, could be wrong though. Link to comment Share on other sites More sharing options...
subeman90 Posted March 28, 2005 Share Posted March 28, 2005 ^^^^^ correct! If you are looking to put a turbo tranny in a NA car you can with a little bit of part swapping. I did this on a 90 AWD wagon.....just make sure you change the diff: turbo=3.9 na=4.11 (unless you are talking about someting newer than it might be a 4.44 (assuming you are talking about 90-94 legacys) Matt Link to comment Share on other sites More sharing options...
XSNRG Posted March 29, 2005 Author Share Posted March 29, 2005 want to know the difference in the trans, I didn't know about the clutch. Mainly I was wondering about the center diff, are they the same? Link to comment Share on other sites More sharing options...
Legacy777 Posted March 31, 2005 Share Posted March 31, 2005 yeah i think the center diff is the same. Link to comment Share on other sites More sharing options...
XSNRG Posted April 2, 2005 Author Share Posted April 2, 2005 So when I see an add for a turbo leg that states "true 50/50 torque split" it isn't something unique to the turbo trans? Just bull? Link to comment Share on other sites More sharing options...
beezer Posted April 2, 2005 Share Posted April 2, 2005 Think it just means it is a manual, the auto's have a 90-10 split under normal conditions I think. Link to comment Share on other sites More sharing options...
Legacy777 Posted April 3, 2005 Share Posted April 3, 2005 doesn't really matter about turbo or auto. It's the trans. As beezer mentioned, mt's have 50/50 torque split. the older autos have 90/10 under normal driving. The newer ones are 45/55. Link to comment Share on other sites More sharing options...
