ausubaru92 Posted March 29, 2005 Share Posted March 29, 2005 Has anybody changed the colour of their Instrument panel Illumination? I was thinking of how it could be done, simply colouring the globes?, using LED's?, has anybody tried/done/succeded this before? Link to comment Share on other sites More sharing options...
subaru_styles Posted March 29, 2005 Share Posted March 29, 2005 on my wagon everything is red...swapped in colored bulbs, some with leds, made custom red filter for the fan speed #'s, i still need to soilder in led's inside some of the switches as it's not 100% done.. i plan on doing the same for the coupe (red), however with the gauge cluster i will be using blue and ultra violet backlighting and dayglo needles, simmiliar to that new VW look Link to comment Share on other sites More sharing options...
ausubaru92 Posted March 29, 2005 Author Share Posted March 29, 2005 Mmmmmmm, UV there's an idea:brow: My illumination is a yellowish colour (when i had it apart, the clear plastic wasnt tinted like my other one, it was green) so i assume that changing the colouring wouldn't be that hard. Link to comment Share on other sites More sharing options...
alexb1 Posted March 29, 2005 Share Posted March 29, 2005 how are you going to change the green color , isn't it molded in the back? Link to comment Share on other sites More sharing options...
ausubaru92 Posted March 29, 2005 Author Share Posted March 29, 2005 I should have explained that better,.. the one in my car has a clear back, the old one that is sitting on my bedroom floor has a green tinted back. Link to comment Share on other sites More sharing options...
alexb1 Posted March 29, 2005 Share Posted March 29, 2005 are you sure , couse if we have the same panel and i think we do then it's not completly clear , some thing has to give the yellow colour . when i had my panel a part it had also some kind of green/yellow background, i tryed to scrape it of but it is like one asembly so i cant see how to take it of. try to paint one bulb and look if the color changes , if it does then you are wright it is clear and you can change to any colour. Link to comment Share on other sites More sharing options...
mtsmiths Posted March 29, 2005 Share Posted March 29, 2005 Well, my '58 Chevy had red bulbs in all the instruments. They didn't make them then, at least in the sizes I needed, so I used glass dye and painted them red. Dome light too. Link to comment Share on other sites More sharing options...
85Sub4WD Posted March 29, 2005 Share Posted March 29, 2005 are you sure , couse if we have the same panel and i think we do then it's not completly clear , some thing has to give the yellow colour ./QUOTE] yes it should be clear - ran into same issue when I was working on my casette deck - the yellow tint seems to come from a sort of "dimming" on the bulbs (or they are naturally that color - dimmed incandescent bulbes are yellow - later models use a green I/P, early ones use yellow - theoretically you could color the dash any color you want - have fun Link to comment Share on other sites More sharing options...
Sister7 Posted March 30, 2005 Share Posted March 30, 2005 Well, my '58 Chevy had red bulbs in all the instruments. They didn't make them then, at least in the sizes I needed, so I used glass dye and painted them red. Dome light too. Finger nail polish also works quite well on bulbs and it's cheap. I've had several tail lights painted in this fashion. Link to comment Share on other sites More sharing options...
Ross Posted March 30, 2005 Share Posted March 30, 2005 Finger nail polish also works quite well on bulbs and it's cheap. I've had several tail lights painted in this fashion. Thats the female solution to everything isn't it? Link to comment Share on other sites More sharing options...
subaru_styles Posted March 30, 2005 Share Posted March 30, 2005 well if im correct the early ea82 gauges had yellow/orange numbers on the cluster where as the later ones (87+???) had white numbering Link to comment Share on other sites More sharing options...
